FRA Flexible Radio Assignment - will not run
steiostb1
FRA will not run to calculate COF. DCA interval is set to 10 minuttes interval. Running two 2802 APs on a 8540 WLC with software 8.2.170.0.
After several days, FRA have still not started:
(Cisco Controller) >show advanced fra
FRA State........................................ Enabled
FRA Sensitivity.................................. medium (95)
FAR Interval..................................... 1 Hour(s)
AP Name MAC Address Slot Current Band COF % Suggested Mode
AP0000.0000.0000 40:ce:24:92:44:00 0 2.4GHz None None
AP08EC.F580.2E08 08:ec:f5:96:06:c0 0 2.4GHz None None
Any tips?
5 Replies 5
Ric Beeching
Level 7
Level 7
Hey very lazy response but can you upgrade to a recommended code like 8.5.140.0 and we can tshoot from there? :-)
Please rate helpful / correct posts
patoberli
I don't anymore fully remember FRA when it was introduced. But I think you needed 8.3 or newer for automatic functionality. So I also recommend you upgrade to 8.5.140.0 (unless you have APs that aren't anymore supported by >8.2 releases). There FRA works nicely.
Haydn Andrews
As mentioned upgrading if possible could help.
How close are the APs?
Going off this statement in the RRM White paper:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_RRM_White_Paper/b_RRM_White_Paper_chapter_01000.html
FRA evaluates 2.4 GHz coverage only and determines if there is overlapping coverage creating interference
Cisco's FRA does 3 things:
  • Calculates and maintains a measurement of redundancy for 2.4 GHz radios and represents this as a new measurement metric called COF (Coverage Overlap Factor)
  • Manages radio “role” assignment or re- assignment for interfaces that are marked as redundant interfaces
  • For Macro/Micro implementations (2800/3800 I models) FRA Manages Client load balancing across dual 5 GHz interfaces (Macro/Micro Transition)
I would guess FRA only comes into play more when you have 3 or more APs, also based on all the examples in the whitepaper are using 3 or more APs
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Thank you all for responding.
I have connected a total of 3 APs and still FRA is still not running. The APs are placed phyically on top on each other to provoke a high COF number.
We are currently using 8.2.170 on our production WLC, because of old APs.
According to this documentation, FRA is implemented from 8.2MR1:
I think you need 4 APs, all on the same 2.4 GHz channel. You also need to have DCA enabled with at least U-NII-2 band channels, because FRA will put the second radio only on 5 GHz if there are 100 MHz space between the two radios.
