Google Chrome with 7.5.102.0
jeustace
I upgraded a customer 5508 to 7.5.102.0 the other day and now can't access the GUI using Google Chrome.  I get a page saying "SSL connection error".
It works fine with Internet Explorer and Firefox.
The final Wireshark packet in the Chrome trace says "Handshake Failure".
Have upgraded Chrome and tried with different laptops with the same result.
I have also upgraded our lab controller (also a 5508) and that's the same.
Anyone else seeing this?
Hi Guys,
This is being investigated.
Chrome 29 adds TLS 1.2 support, and WLC is selecting a crypto suite over TLS 1.0 that apparently is breaking client.
Try this workaround for now.
config network secureweb cipher-option rc4-preference enable
Save and reboot required.
Sahil
13 Replies 13
Scott Fella
Yeah.... its when I upgraded my Google Chrome!  I had v7.5 running fine until I upgraded my browser.  If you google it, other have ran into this issue in general.  I think that Chrome has corrupted information that has to be removed, but where to remove it is the questions.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
fsouzabr
Any news about this issue?
We are facing exactly the same problem.
Cheers.
I have the same problem too. Additionally Guest Wireless portal also not working for Google Chrome clients after upgraded to 7.5.102.0. Looking for permenant fix without ask to change the browser (in guest scenario not possible to do this & most of android devices comes with chrome as default browser)
Rasika
Hi Guys,
Sahil
Sahil,
That worked!
Scott
-Scott
That works. Thank you.
Hi Sahil,
Thank you very much for quik response & give a workable solution. I have applied this and guest wireless issue with chorme has vanished..
Thanks again & +5 for you
Rasika
Hello guys!
That worked for me too!!
Many thanks Sahil!
Sahil
+5
Great, I will also try this. But if it does not work or it is fixed in a later version, how do I revert this setting?
With:
config network secureweb cipher-option rc4-preference disable
Thanks Sahil for sharing this useful information with community users 5+ :-).
This document was generated from the following discussion
Unable to access 5508 controller GUI with Google Chrome after upgrading to 7.5.102.0 - "SSL Connection Error"
Vinay Sharma
Community Manager
Thanks & Regards
jeustace
Works for me too.  Thanks for the info!
Chellis Dodge
Well done Thanks for the Fix
