08-18-2011 09:29 AM - edited 07-03-2021 08:35 PM
Good Afternoon,
I have arrived on a site with three Cisco 1131AG Wireless Access Points WITHOUT a controller.
I want to run these in Autonomous Mode so I can use them in a more "small business" way, that is with one AP being the Root Access point with the other two being repeaters - is this the best thing to do?
Unfortunately, I don't seem to be able to download an image to convert them back to autonomous mode, can someone help me:
1) To double check on the console that they are in Lightweight Controller Mode (thus need changing).
2) Send me a link where I can download the software, the CISCO site tells me I need a service contract which is very frustrating
3) Any other hints or tips!
Many thanks
M
08-18-2011 04:17 PM
Boot the AP and post the command output of "sh version".
08-19-2011 04:08 AM
Cool, it is the LWAPP version:
cisco AIR-LAP1131AG-E-K9 (PowerPCElvis) processor (revision C0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1527Q1MR
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
Any ideas how I can download the other image?
08-19-2011 04:42 AM
U need the contract the download the image.. if the device is under warranty then please open up a case with us and we will help u out in getting image published.. if not, then i guess some forumers may help u if they hav a copy!!
Please dont forget to rate the usefull posts!!
Surendra
08-19-2011 06:30 AM
Hey Surendra,
Thank you for this, the device is about 2 weeks old if that!!
Are you able to tell me the URL or how I can go about opening up a case as you suggest?
Many thanks
M
08-19-2011 06:37 AM
Hi Matt,
here is the TAC toll free number..
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
please contact the respective country phone number and inform them the Serial Number of the device and they will help you out in getting the case opened!! an engineer will contact u and help u out in getting the issue resolved!!
Surendra
