Cisco Community Designated VIP Class of 2020
383
Beginner
home waps
planning to use cisco waps for home - ceiling mounted.
I have 3 ceiling drops in 3 locations. I am planning to use the Cisco 571 or 581. and get a cisco poe switch in the closet.
do i need any license or software to manage these waps if I get the waps from ebay?
3 REPLIES 3
Beginner
Re: home waps
any idea?
Hall of Fame Master
Re: home waps
This forum is more enterprise related AP's and those apps you mentioned is more home, small business. My take is depending on what you want, Cisco makes Mobility Express AP's that can be a great fit for your home. I run a few controllers and 6 wired AP's, but its also where I do some of my testing.
https://www.cisco.com/c/en/us/solutions/enterprise-networks/mobility-express/index.html
-Scott
Highlighted
VIP Advocate
Re: home waps
For home I personally would not buy Cisco Enterprise APs (don't know those WAP series at all, only Enterprise models). I personally went the Ubiquiti route for my home. You might also want to check the Meraki solution for at home.
Content for Community-Ad
August's Community Spotlight Awards
