How do I copy a Prime Backup from repository default repo to repository FTP in CISCO Prime
garyleggat
How do I copy a Prime Backup from repository default repo to  repository FTP in CISCO Prime 2.0
5 Replies 5
garyleggat
copy disk:/defaultRepo/filename ftp://myipaddress
this copes it to my ftp server on laptop but if I try this to copy to ftp in PI
copy disk:/defaultRepo/filename ftp:/ it ask me for username and password but it keeps saying transfer failed
Try this:
-login as root
- cd /localdisk/ftp (or whatever your ftp-dir is)
- scp /localdisk/defaultRepo/filename filename
I have the same problem, did you fix it? if yes then kindly explain and which software you used for FTP.
Kind regards,
VImal.
My fTP to a remote ftp server worked fine with the following command:
PRIME/admin# copy disk:defaultRepo/[here goes your file name xxx.tar.gpg] ftp://xx.xx.xx.xx (your FTP server IP address)
Username: [your ftp user name]
Password: [your FTP password]
I use Filezilla server and I had to make sure that the user name and password were correct by creating a new user. i had experienced a couple of failures due to a password failure and the wrong name of the file I was copying. Double Check both.
What christos.minias@mah.org is correct and should work, but your local firewall/antivirus can block the copy action.
-Disable temporary your antivirus/firewall on your laptop (eset/ MS firewall etc).
-if this not working, then check if you can ping your laptop from Prime. If not, add a route towards the subnet of your laptop.
That should fix it i hope.
