Participant
How do you clear 802.11 MAC Counters
I am trouble shooting some wireless issues. Before I make the changes I am gathering the data from the AP's I am working with. So that I have a clear and accurate account to compare with after the changes are made. That said, I am using the details from the Monitor>Accesspoints>802.11b/g/n in particular the 802.11 MAC Counters. Is there a way to clear the 802.11 MAC Counters, so that I have accurate information once I make my changes?
Thanks in advance.
Bret
4 REPLIES 4
Very good question Bret.
I have no idea how that can be done and I hope someone can help is to find out the solution.
I tried to clear the counters from the AP itself. However, this did not clear the MAC counters that appear on the WLC.
Amjad
Rating useful replies is more useful than saying "Thank you"
Highlighted
Hall of Fame Community Legend
Reboot the AP & the counter clears.
Beginner
Re: How do you clear 802.11 MAC Counters
AP TELNET clear counters dot11Radio 0 clear counters dot11Radio 1
Hall of Fame Master
Curious on why you are doing this when you can capture the existing counter info. What issue are you troubleshooting, as there might be a better way. Rebooting the AP like Leo mentioned clears everything on the AP, but at times also helps if you are hitting a bug. If making changes on the WLC, capture existing data and then compare after the change. What issues are you having?
-Scott
Content for Community-Ad
August's Community Spotlight Awards
