Community Helping Community
447
Highlighted
Beginner
How many wireless user can use the same account create in the data base of WLC?
How many wireless user can use the same account created in the data base of WLC? (for visits)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: How many wireless user can use the same account create in th
You can have unlimited or else you can set the limit to 0-8.
The Maximum Number of Concurrent Logins for a single user name by default is 0. You can enter any value between 0 and 8. This parameter can be set at SECURITY > AAA > User Login Policies and allows you to specify the maximum number of concurrent logins for a single client name, between one and eight, or 0 = unlimited.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807f42e9.shtml
-Scott
3 REPLIES 3
Hall of Fame Master
-Scott
Beginner
THank you very much as always
Hall of Fame Master
No problem... Thanks for using the rating system.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
