12-20-2015 07:22 AM - edited 07-05-2021 04:25 AM
Hello.
I see that the output for #show dot11 associations has a Name column. I wonder if it is possible to assign a an arbitrary name to the associated clients in order to distinguish them better.
I bought an AIR-CAP3602I-A-K9 AP recently to dive into the APs world. Yesterday I turned it into autonomous and now I'm setting it up.
Thanks!
Solved! Go to Solution.
12-26-2015 05:48 AM
The field you are referring to is automatically completed with the help of the Cisco Aironet extensions, which requires the client to be CCX compatible. Below the output of a 7925 phone connected to a autonomous access-point.
MAC Address IP address IPV6 address Device Name Parent State
30f7.0d4d.9aa5 192.168.101.237 :: CP-7925 SEP30F70D4D9AA5 self EAP-Assoc
It does not mater if the SSID is using RADIUS for authentication or not in this case (with a WLC this RADIUS information is actually being used to completed the "user name" field).
Please rate useful posts... :-)
12-20-2015 09:25 AM
Also, does this AP support PoE in standalone mode?
12-26-2015 04:09 PM
Yes, it does. I just tested it.
12-24-2015 01:50 AM
3600 series supports : 802.11n: 802.3af, AC adapter 802.11ac*: Enhanced PoE, 802.3at or Universal PoE (UPOE)
12-26-2015 05:48 AM
