06-18-2019 04:15 AM - edited 07-05-2021 10:34 AM
HI everyone ,
I know the AP3800 support dual 5GHz mode,but we want to use 2.4G & 5G mode.I don't know how to check and change it .Could you please tell me how to change dual 5GHz mode to 2.4 & 5GHz mode?
Thanks a lot !
06-18-2019 04:22 AM
06-18-2019 04:28 AM
06-18-2019 05:01 AM
@Rps-Cheers wrote:
Yes, i think so,but where i can disable the FRA ? I didn't find it in GUI.
Wireless > Advanced > RF Management > Flexible Radio Assignment
06-18-2019 04:35 AM
06-18-2019 09:50 AM
06-18-2019 04:34 AM
Hi. You can do this manually on the WLC itself.
Try
config slot 0 disable "AP-Name-Here"
config 802.11-abgn role "AP-Name-Here" manual client-serving
config 802.11-abgn band ap "AP-Name-Here" 2.4GHz
config slot 0 enable "AP-Name-Here"
Andy.
06-18-2019 04:41 AM
06-20-2019 01:14 PM
I do believe that once you follow Leo's guidance: Wireless > Advanced > RF Management > Flexible Radio Assignment
and select Disable, Since this is a Global command, the AP radios that are in the 5g mode will reset back to 2g.
In the auto mode the wlc only moves the radio from 2g to 5g if there is plenty of 2g coverage
06-20-2019 02:52 PM
also Wireless/Access Points/Radios/Dual-band Radios
will present you your list of 2800/3800 dual band modules..
mouse over to the blue down arrow and select .. configure.
Radio role Assignment
typically Auto... make it Manual/Client serving and band 2.4G.
06-20-2019 07:55 PM
