273
Highlighted
Beginner
how to check number of Access point under mobility express controller through snmp
Hi Tech,
I have a few AP join to mobility express (ME) controller (on one AP point) and they could manage through one static management IP.
the question is. How could i monitor the status of each Access point through SNMP?
I could monitor the status of the management interface. but i could not check the status of the access point. (all access point is standalone with static ip)
Do you all have any suggestion for the MIB file or OID of the status of the access point?
how to check the quantity of the AP join the ME controller?
Everyone's tags (2)
2 REPLIES 2
Re: how to check number of Access point under mobility express controller through snmp
If you have ME controller, then you can issue the following command to show the number of APs associated with it
"show ap summary"
or you can log into the GUI and go to "Network Summary --> Access Points" will list out the APs joined the ME.
Hope this helps,
Jagan
Beginner
My main point is show it Through SNMP.
Content for Community-Ad
July's Community Spotlight Awards
