11-20-2018 09:22 PM - edited 07-05-2021 09:29 AM
I have AIR-CAP3502 Which works in an automous configuration
I want to know how I reduce the transmission power to a minimum
Is the rest of the settings that appear on the screen here are good ? (Attached is a screenshot)
what is
"Internal Antenna Configuration"
"Aironet Extensions"
"World Mode Multi-Domain Operation"
"11r Configuration"
I have a 4 AP at home connected to a simple router (home devices edimax, level1, dlink)
All of them have the same network name and password
When I move from one room to another a device connects to the AP with that high power
Now I changed AP in one of the rooms
And now for some reason the cell phone or laptop prefer to connect to Cisco's AP which is in another room (because of this I want to lower its power)
11-20-2018 09:24 PM
11-21-2018 08:34 AM
11-21-2018 09:22 PM
11-21-2018 09:25 PM - edited 11-21-2018 09:28 PM
11-22-2018 12:08 AM
I actually haven't used this web interface is the last ~10 years so I don't remember :)
You can configure everything on the CLI, for this connect via Console or SSH or Telnet to the AP.
The channels are still wrong though. Just mark 1, 6 and 11, while holding the control key on the keyboard. Just those three channels should remain green.
The country selection doesn't matter much, it's not required for normal operation.
11-22-2018 12:43 AM
11-22-2018 12:58 AM
11-22-2018 09:32 PM
11-22-2018 11:46 PM
Disable World Mode, then you shouldn't need to select a country.
11-24-2018 01:22 AM
11-24-2018 02:43 AM
11-25-2018 09:27 AM - edited 11-25-2018 09:28 AM
11-27-2018 02:28 AM
In the first square you marked
when i want to save i get an error
Reassociation Time' must be between 20 and 1200
what is Reassociation Time ?
and what number i need to put over there ?
I did not understand the part on the antenna
12-01-2018 09:32 PM
