09-17-2019 12:54 AM - edited 07-05-2021 11:01 AM
anyone deployed 9800-CL on VMWARE environment ??
I am able to deploy 9800-CL with SSO on single UCS chassis.
Dont know how to setup UCS chassis for SSO of 9800-CL
09-17-2019 07:08 AM
here is the deployment guide
09-17-2019 02:16 PM
Not possible:
HA Pair can only be form between two wireless controllers of the same form factor
Both controllers must be running the same software version in order to form the HA Pair
Maximum RP link latency = 80 ms RTT, minimum bandwidth = 60 Mbps and minimum MTU = 1500
-If I helped you somehow, please, rate it as useful.-
09-17-2019 07:32 PM
So if I have one 9800 virtual controller A on UCS chassis A and one 9800 virtual controller B on UCS chassis B in this scenario configuring SSO between Controller A and Controller B is not possible?
09-18-2019 05:45 AM
Never tried but as per the doc, it is not. WLC installed on the 9300, for example, does not support SSO between switches in different stacks, only on the same stack.
09-18-2019 09:58 AM
I believe you're misinterpreting the docs there. Requiring the same form factor means you can't HA an -40 with a -CL, but you can pair two 9800s of the same type.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller_ha_sso_dg.html#id_73191 has an example where WLCs on two separate physical servers work together in SSO.
09-20-2019 02:09 AM
Correct. C9800-CL HA Pair can be formed across two separated physical servers, you just need to map the RP port to a vSwitch/portGroup NIC on a dedicated VLAN and then carry that VLAN across to the other server. This can be directly connected or through a L2 switch.
Simone
09-20-2019 05:22 AM
Ok that sounds good,
We will try and let you know about this.
