03-08-2010 04:29 AM - edited 07-03-2021 06:35 PM
I am trying to disable 802.11n access to the guest WLAN (SSID "open"). I tried to configure the WLAN with 802.11g access only but "n" clients are still able to connect. I'm extremely green when it comes to wireless config so I'm way out of my element here. I've attached a picture of what I thought should have done the trick. Any suggestions?
Solved! Go to Solution.
03-08-2010 06:00 AM
What you can do is go to your WLAN SSID and under the QoS feature, disable WMM. WMM is required for 802.11N support... Test is out and hopefully that solves your issue.
03-08-2010 06:00 AM
03-09-2010 09:54 PM
Disabling WMM, as Scott suggested, should do the trick.
03-15-2010 05:13 PM
Scott,
That did the trick. All the "n" connections dropped and reconnected via "g". Thanks for your help.
-mike
03-15-2010 06:15 PM
Glad it worked out for you.
05-25-2011 11:38 AM
That solved an issue I had.
Was not able to make 802.11n working at all.
You aimed me at the right direction.
Thank you so much.
Ivan
02-18-2014 04:37 PM
Scott we just ran in to this and found your answer. Thank you for replay!!
02-18-2014 06:52 PM
That's nice to hear that others can find an older post and still use it:).
Glad it worked for you!
02-18-2014 09:24 PM
Its Amazing, Thanks Scott 5+ :-)
Thanks & Regards
Vinay Sharma
Community Manager
02-18-2014 11:50 PM
Thanks Vinay!!! I have seen more lately which is a good thing. I too use the search and reference older threads, but glad to see that others actually who don't really post on the forums find it useful. Now if I can get my peers to search the forum instead of emailing me, life would be good:)
03-08-2010 03:30 PM
"n" requires WPA2/AES or OPEN authentication. So if you DON'T use the following ...
02-24-2012 11:38 AM
Added this useful information in the document:-
https://supportforums.cisco.com/docs/DOC-18507
