228
Highlighted
Beginner
how to identify the unregistered access points
i have 5520 cisco WIFI controller and the model of AP is AP1810W , it is working fine but if any access point goes down for any reason i can't see any alarm or log on the controller to identify which AP is down just i can know that the number of registered AP has been reduced .
1 ACCEPTED SOLUTION
Rising star
Re: how to identify the unregistered access points
- Better is to have Cisco Prime too for wireless management , which will offer more direct info ; also check :
          https://community.cisco.com/t5/wireless-and-mobility/how-to-know-which-access-point-is-down-on-wlc/td-p/2370873
 M.
3 REPLIES 3
VIP Advisor
How are you managing this WLC (using Prime Infra ), then you can setup a Logs or use SNMP send alerts for the AP lost joining Controller.
BB
*** Rate All Helpful Responses ***
Rising star
 M.
Beginner
thank you i found what i need on the shared link :)
Content for Community-Ad
August's Community Spotlight Awards
