Hello - a bit confused on how to go about setting up WPA security on the AP 1200.
Searching for steps but have not found any yet. Anyone? Thanks
Solved! Go to Solution.
Strange...I get to it fine. Here it is again (without wrapping, I hope):
Do you see it now?
And here's the 2nd one:
Hi.
Here is a document which shows how to configure WPA on your access point.
http://www.cisco.com/en/US/partner/products/hw/wireless/ps4570/products_conf
iguration_example09186a00801c40b6.shtml
In order to configure the AP for WPA you need to configure EAP on you AP as well, which is not mentioned in the above document. So here is another document which tells how to configure EAP on your AP. You just need to follow the part shown for the access point only & not the ACS part in the document.
iguration_example09186a00801bd035.shtml
Hope this helps.
I appreciate the reply. However I receive:
The Page You Have Requested Is Not Available
I am aware the link is wrapped and made sure I had all the infoentered correctly in the browser but unable to get to the docs. Anyone else can get to them? If not does anyone else have any hints or tips and step by step hot to?
Do you see it now?
LOL. No for some reason I connot.. I am logged in as well. Do I need higher access lol
Perhaps directly emailing to me?
...very strange...you should be able to see it, as it's on the public site. Send me an email and I'll reply to it with the documents attached.
PS. Please don't forget to rate this conversation. ;-)
