5121
Rising star
How to use wireshark to decode WLC Packet capture
I am using the WLC packet capture feature (refer to the link below) to capture the traffic from a client.
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_01101111.html
My setup is as below.
(Cisco Controller) >show ap packet-dump status
Packet Capture Status............................ Stopped
FTP Server IP Address............................ x.x.x.x
FTP Server Path.................................. \
FTP Server Username.............................. xxxxxx
FTP Server Password.............................. ********
Buffer Size for Capture.......................... 2048 KB
Packet Capture Time.............................. 2 Minutes
Packet Truncate Length........................... 300 Bytes
Packet Capture Classifier........................ IP
I captured the packets successfully but the problem is that Wireshark did not decode it correctly (refer to the screenshot below). Does anyone use this feature before? If yes, how could I decode it and see the IP address TCP/UDP port info.
Thanks for your help.
-Kevin
11 REPLIES 11
check and make sure you have the swap frame control enabled.
Edit > Preferences > CAPWAP  I'd also check LWAPP as well
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Rising star
Thanks Stephen.
Tried but It wounldn't help.
For reference is your wireshark configured like this ?
http://wifinigel.blogspot.com/2012/04/decoding-cisco-capwap-with-wireshark.html
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Highlighted
Rising star
Thanks George. Yes, I did configure Wireshark the same way.
In the link you provided, the packet was captured from switch between WLC and AP, so the packet for sure is encapsulated in CAPWAP frame.
But the feature which I am using might capture the packet between AP and client since it can capture beacons and probe response as well. The WLAN is ocnfigured to use WPA-PSK, so, I enable IEEE 802.11 decrytion as well with the correct PSK but it still did not help. I am suspecting if I did not convert PSK from ASCII to Hex correctly or something else. It got be some way to decode it otherwise this feature would be useless for troubleshooting.
Rising star
Figured it out finally based on the following link.
http://wiki.wireshark.org/HowToDecrypt802.11
1. 4 EAPOL handshake packets must be captured
2. "Ignore the Protection bit" set to "Yes - with IV"
But unfortunately, I only see traffic in one direction, not sure why.
Rising star
Thanks for Sharing the solution. For your other problem you should check the below link again.
Beginner
Did you ever figure out why
Did you ever figure out why captured traffic was unidirectional? I'm seeing the same issue
Beginner
David, Did you ever figure
David, Did you ever figure out your Uni-directional issue? I have the same issue, strange.
Beginner
I wish... I've had to settle
I wish... I've had to settle for a one-sided capture since I haven't opened a TAC case yet
Beginner
Hi Ken,
Hi Ken,
I found out half an answer
it seems like if you mess with the wireshark protocol preferences for IEEE 802.11
you have the option for "ignore the protection bit" either as "no", "Yes - without IV" and "Yes - with IV"
looks like if you set it to "Yes - With IV" you will see the client side of communication properly decoded and if you switch it to "Yes - without IV" you will get the server side properly decoded
I am not sure what the setting actually does beyond ignoring the protection bit and I have a TAC case open as well. maybe i'll get to the bottom of this
Re: Hi Ken,
Did you ever get an answer or a solution to this?
Content for Community-Ad
July's Community Spotlight Awards
