i can,t get full data transfer rate on cisco 3602 AP
RASHID ASGHAR
version 15.2
no service pad
service password-encryption
hostname Php
logging rate-limit console 9
enable secret 5 $1$icM5$N/nc3E1UFeA6He0/WUtO/1
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid Php
   authentication open
   guest-mode
dot11 band-select parameters
   cycle-count 3
   cycle-threshold 200
   expire-supression 20
   expire-dual-band 60
   client-rssi 80
dot11 network-map
dot11 adjacent-ap age-timeout 1000
dot11 guest
username Cisco password 7 106D000A0618
username admin privilege 15 secret 5 $1$N9mw$Bzw6WJypMzG0hCc9XaRQV/
bridge irb
interface Dot11Radio0
bandwidth 10000000
no ip address
no ip route-cache
encryption key 1 size 40bit 7 8A0DE8A0C95E transmit-key
encryption mode wep optional
ssid Php
antenna gain 0
stbc
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
bandwidth 10000000
no ip address
no ip route-cache
encryption key 1 size 40bit 7 D20EB4C0DC26 transmit-key
ssid Php
antenna gain 128
peakdetect
no dfs band block
stbc
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.11 255.255.255.0
rate-limit input 2000000000 512000000 1024000000 conform-action transmit exceed
-action transmit
rate-limit output 2000000000 512000000 512000000 conform-action transmit exceed
-action transmit
no ip route-cache
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Scott Fella
First off, to achieve better rates you need to look at 802.11n standards.
You need to use open or WPA2/AES, WEP and WPA/TKIP is not supported. WMM needs to be enabled on the WLAN and under the 5ghz radio, you need to have channel width set to 80. You also need to have a 802.11n client or an 802.11ac client to see the higher speeds. How your ap
Is configured, you will see the basic rates.
-Scott
Just to add, since your 3600 does not have ac module on it, max channel width you can set is 40MHz on Radio 1 interface.
Here is suggested configuration to get it working. I have used WPA2/AES with PSK
dot11 ssid Php
   authentication open
   guest-mode
   authentication key-management wpa version 2
   wpa-psk ascii
encryption mode ciphers aes-ccm
ssid Php
speed  default
station-role root
bridge-group 1
ssid Php
channel width 40-above
speed  default
station-role root
bridge-group 1
As long as you have a device with 3SS support on 5GHz  you should get highest data rates ( theoratical max 450Mbps, practically around 200Mbps). If it is 2SS  then you will get max 300Mbps (theoratical). Below should help you to get an idea about those MCS data rates
Rasika
**** Pls rate all useful responses ****
Scott Fella
Good catch... I was thinking it was a 3702:)
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
