Implement WLAN
junshah22
Hello all,
I am going to implement Wireless LAN in my new office, I will be using Linksys Wireless Router,
can you please tell me how much area it will cover, I mean in rooms, or I have to add Access Point for each Room..
Junaid
andrew.brazier
Level 4
Level 4
Depends on many factors. What are the internal walls made of? Are there any sources of RFI interference? How big is the building?
The only way to tell for sure os to carry out a wireless survey. The simplest thing to do would be to install the wireless router and do a walk-around test with a laptop to see what coverage you get in the areas you require it. You can then install additional APs as required.
