04-15-2019 12:13 AM - edited 07-05-2021 10:15 AM
Hello All,
I deployed a wireless network on AIR-AP1832I-R-K9, firmware version 8.7.102.0, in the mode Mobility Express.
When users log on, they go to the internal authentication page to enter their login and password.
What certificate should be used for this page, and should it be additionally specified in the WLAN settings?
In the documentation I found a description of how to add certificates, but I did not find any description or purpose.
I will be grateful for the help, or the link to the necessary manual.
Solved! Go to Solution.
04-15-2019 06:44 AM
04-19-2019 09:24 AM - edited 04-19-2019 09:25 AM
Hi Amrich,
Try using this command on the WLC CLI to create a host-name for Virtual IP Address. Reboot will be required.
config interface hostname virtual <URL.domain>
04-15-2019 04:58 AM
04-15-2019 05:19 AM
04-15-2019 06:44 AM
04-18-2019 11:22 PM
Thank. This instruction helped add a certificate.
However, the login and password entry page opens at https://192.0.2.1/login.html. Therefore, I get the error "The certificate of security of this web site is issued for a web site with a different address."
Is it possible to specify the address of this page using the name of my domain?
Hi Amrich,
04-22-2019 03:43 AM
04-22-2019 03:45 AM
04-15-2019 06:49 AM
04-18-2019 11:26 PM
