What is radio X? You should find out what frequency radio x operates on. As you know, if radio x runs either on 2.4GHz or 5GHz, you will most likely have interference. If you happen to not know what frequency radio x is using, then you will have to get a hold of a spectrum analyzer to see if radio x is using one of the frequencies.
-Scott
