04-18-2011 12:06 AM - edited 07-03-2021 08:05 PM
Dear Experts:
in my implementation, we need 2 WLANs be served on the same anchor controller.
WLAN1: wep/40bit, integration with NAC/OOB on anchor controller for guest wlan service.
and guest account controlled by NACguest server.
WLAN2: wep/40bit, no layer3 secuirty for temporary using.
foreign controller: WiSM on v6.0.196.4 (also testing on 6.0.182.0)
anchor controller: WLC4402 on v6.0.196.4
on WLAN1:
Windows7 client get ip address correctly.
iOS (iPhone4 on 4.3.1/4.3.2, iPad2 on 4.3.1/4.3.2) can get ip address correctly on WLAN1.
WLAN2, iOS device cannot get ip address.
compare with debug message "debug clien mac" + "debug dhcp message enable"
on both foreign and anchor controller.
on foreign controller:
PM state has changed from: DHCP_REQD (7) Change state to RUN (20) last state RUN (20)
on anchor controller:
PM state always stay on: DHCP_REQD (7) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
Enable/Disable DHCP Address Assignment Required is not work.
Enable/Disable DHCP proxy is not work.
Any hit this issue when get ip address failed in multiple WLANs on the same anchor controller?
In attachment log file,
DMZ.log: anchor controller on DMZ.
S3p1.log: WiSM on v6.0.182.0
S3p2.log: WiSM on v6.0.196.4
client mac: 00:1f:3b:05:33:c1, Windows7 Client
client mac: 58:55:ca:cf:d2:07, iPhone4 with 4.3.1,
WLAN1 subnet: 10.61.246.0/23
WLAN2 subnet: 10.61.248.0/23
04-18-2011 01:28 AM
Can you please send "Show run-config" from all WLCs ?
Thank you
04-18-2011 01:57 AM
Hi, Nicolas:
just checking the attachment for the run-config on foreign/anchor controller.
DMZ_run.config - anchor controller
s3p1_run.config - WiSM on v6.0.182.0
s3p2_run.config - WiSM on v6.0.196.4
at this moment, we have disable the wlan 10 on foreign controller, and wlan 2 on foreign controller.
Wilson...
08-25-2011 11:13 AM
Hi Wilson,
Please mark the Question as Answered, if the provided information is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
