iPad- SSID hop doesn't work
pfillips11
We have two SSID's Guest and Corp. We are using 5508 controllers.
The problem is that if an iPad user is connected to Guest SSID and then try to connect to Corp then it fails saying "Unable to connect to Corp". After 10-15 retires the same iPad connects successfully. The problem doesn't happen on windows PC. I have attached debug for one of the clients.
Any assistance is appreciated.
Thank you.
George Stefanick
One of the items you might want to check is to see if enable fast ssid change is enabled.
I bloged about this
http://www.my80211.com/home/2010/5/9/wlc-configuring-fast-ssid-changing.html
Give that a shot ..
