Is beacon support available? 1815w 1832i 9800wlc
jbseong
I am using a 9800 controller with ap 1815w and 1832i models.
Can I build a beacon with this model?
Yes, these models of APs are supported by 9800 WLC. Refer below document & keep it as a reference
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Beaconing is a fundamental way of advertising SSIDs to its client.
Rasika
*** Pls rate all useful responses ***
What I mean is this beacon.
https://www.cisco.com/c/en/us/td/docs/wireless/cmx_cloud/vBLE_HIG/b_ble2_hig/b_ble2_hig_chapter_01.html
Or ble beacon. We want to know where our equipment is moving.
Like gps
The newer 91x0 AP’s have ble support and can also be a ble gateway. What you need to reference is the data sheet for that specific access point. Doesn’t matter what code or controller if the ap doesn’t support BLE or what you are trying to achieve. With the 9800’s you would need DNA space which also requires DNAc.
-Scott
