Is it supported to use SSID for Flexconnect with remote anchor ?
aoster
Hi all,
I have configured a 5508 controller to connect local and Flexconnect APs. There is an additional 2504 for termination of a guest Internet access SSID. On the 5508 and 2504 I have configured SSID "guest1" and anchoring. This is working as expected, however we want the Flexconnect APs at the remote sites  to use the site local internet breakout. To accomplish this I have also enabled Flexconnect on the "guest1" SSID and added the WLAN-VLAN mappings for the SSID in the Flexconnect groups.
This setup is actually working to 90% but the users at remote sites are facing erratic disconnects. When using central switching (no Flexconnect) or when removing anchoring from the SSID the WLAN connections for the clients are absolutly stable.
Does anyone have a similar configuration in place ? Is this actually supported ?
Thank you for your kind help.
best regards
Andreas
0 Replies 0
