11-14-2013 05:55 AM - edited 07-04-2021 01:15 AM
11-14-2013 06:23 AM
No, it’s not supported with 7.0.240.0. Please check the below table
Controller Software Release | Supported Access Points |
7.4.x | 1522, 1524PS, 1524SB, 1552E, 1552H, 1552I, 1552C, 1552EU, 1552CU, 1552S, 1130, 1240, 1250, 1260, 1600, 2600, 3500e, 3500i, 3500p, 3600e, 3600i, 1140, 600 OEAP, AP801, AP802 |
7.0.2x.x | 1522, 1524PS, 1524SB, 1552E, 1552H, 1552I, 1552C, 1130, 1240, 1250, 1260, 3500e, 3500i, 3500p, 1140, 600 OEAP, AP801, AP802 |
4.1.190.5 (Mesh Release 1) | 1505, 1510, 1522 (US and Canada) |
1600 Series | AIR-CAP1602I-x-K9 | 7.4.100.0 | — | 3.2.0SE | - |
AIR-CAP1602I-xK910 | 7.4.100.0 | — | 3.2.0SE | - | |
AIR-SAP1602I-x-K9 | 7.4.100.0 | — | 3.2.0SE | - | |
AIR-SAP1602I-xK9-5 | 7.4.100.0 | — | 3.2.0SE | - | |
AIR-CAP1602E-x-K9 | 7.4.100.0 | — | 3.2.0SE | - | |
AIR-SAP1602E-xK9-5 | 7.4.100.0 | — | 3.2.0SE | - |
For compatibility Matrix, visit below link:
11-14-2013 06:22 AM
No it's not. Here is a compatibility matrix to keep handy as this shows what code and equipment are compatible.
The 1602 requires v7.4.100.0
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
11-14-2013 06:23 AM
11-14-2013 12:10 PM
Also note that 4400 series WLC cannot go beyond 7.0.x code. So you have to purchase a new WLC (2504/5508/etc) in order to use thise newer AP(1600/2600/3600/3700)
Rasika
**** Pls rate all useful repsonses ****
11-15-2013 01:17 AM
Thanks for the info!
J.
