Highlighted
Enthusiast
Is there any command to check wlc power supply serial number ?
I want to check wlc5508 power supply serial nummer,but we only can check the  power supply status by "show inventory" or "show sysinfo" command.
Is there any command to check the power supply serial number on CLI or GUI ?
Everyone's tags (2)
10 REPLIES 10
Highlighted
VIP Rising star
Re: Is there any command to check wlc power supply serial number ?
Not sure if this will work but it will get the SFP details which are not seen via the show inventory
show inventory raw
or
debug fastpath cfgtool --dump.sfp
reference:
https://mrncciew.com/2014/08/18/wlc-sfp-info/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Highlighted
Enthusiast
HI Haydn
There is no "show inventory raw " command.
I think this mothd is not avaliable,because i have found this link to try.
Highlighted
VIP Advocate
Then the only variant is to pull it out. If you have two, then this should work without an interruption.
Highlighted
It is not possible to find out the power supply serial number through the WLC or via SNMP.
Best regards,
Haifeng
Highlighted
VIP Advocate
If the previous commands don't show it, then probably not.
Highlighted
Enthusiast
Thanks for your reply, i also think so...
Highlighted
Enthusiast
Hi Haifeng
Thanks for your response,i got it.
Highlighted
Enthusiast
But,Is there any way to check the power supply serial number except for the wlc and snmp method ?
Highlighted
VIP Advocate
Yes, it should be printet on a label on the PSU. For this you have to remove it and check the label.
Highlighted
Enthusiast
Ok, it seems that this is the only way
Content for Community-Ad
Cisco COVID-19 Survey
