Is there any command to check wlc power supply serial number ?
I want to check wlc5508 power supply serial nummer,but we only can check the  power supply status by "show inventory" or "show sysinfo" command.
Is there any command to check the power supply serial number on CLI or GUI ?
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
10 Replies 10
Haydn Andrews
Not sure if this will work but it will get the SFP details which are not seen via the show inventory
show inventory raw
or
debug fastpath cfgtool --dump.sfp
reference:
https://mrncciew.com/2014/08/18/wlc-sfp-info/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
HI Haydn
There is no "show inventory raw " command.
I think this mothd is not avaliable,because i have found this link to try.
Then the only variant is to pull it out. If you have two, then this should work without an interruption.
HaifengLi
It is not possible to find out the power supply serial number through the WLC or via SNMP.
Best regards,
Haifeng
If the previous commands don't show it, then probably not.
Thanks for your reply, i also think so...
Hi Haifeng
Thanks for your response,i got it.
But,Is there any way to check the power supply serial number except for the wlc and snmp method ?
Yes, it should be printet on a label on the PSU. For this you have to remove it and check the label.
Ok, it seems that this is the only way
