Community Helping Community
5906
Highlighted
Participant
ISE and PI Integration
Dear All,
What are the configuration required on ISE to integrate with Prime 1.3.0.20?
On PI side, I have added ISE in the below path
Design-> External Management Servers -> ISE Servers.
Apart from this anything else to be done on PI..?
Thanks in advance.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Enthusiast
There is nothing more to be done on the PI. Further configuration tasks are done on the ISE.
Cheers
6 REPLIES 6
Participant
Any Help ...? or i should move this discussion to other spaces
Enthusiast
Cheers
Participant
Exactly.. What should i do on ISE...?
Enthusiast
The stuff to do on the ISE is set up as a Radius Server for your client authentication. When ISE acts as a radius server, Prime Infrastructure collects additional information about these clients from Cisco ISE and provides all client relevant information to be visible in a single console on PI.
The point to remember is that PI is a management sloution for wired and wireless clients, while ISE acts as ACS and NAC combined. Recall that ACS on its own could not do posture validation without NAC.
Cheers
Beginner
Re: ISE and PI Integration
Prasan I also added ISE on prime and it is strange I dont see any change
Have you got additional information on client device from ISE ?
Have you done some thing else from the ISE ?
Please advise
Participant
There is no additional configuration required on Prime. Its like if you add ISE in prime, then you will be able to get information about clients(authentication logs) directly from prime.
Content for Community-Ad
August's Community Spotlight Awards
