04-23-2016 12:04 PM - edited 07-05-2021 04:56 AM
Hi Team,
I am trying to configure MSE HA from Prime infrastructure as per the configuration guide . I added the primary server in Prime infra and clicked on 'Click here' in the Secondary MSE column.
Issue:
As soon as i do this, i am getting the error pop up
"Failed to retrieve status from MSE server. Make sure the server is up and running" But the server is running fine .
Please find the attachment <-----------------------
MSE Type : Virtual Machine
Version : 8.0.130.0 downloaded from CCO
Primary MSE License : Evaluation
I have an Activation license ready for secondary MSE with me . But this error is blocking me to enter the details of secondary MSE for pairing.
The Primary is configured with Virtual IP as well. Please find the 'getserverinfo' and 'gethainfo' output from the primary MSE.:
[root@mseprimary ~]# getserverinfo
Health Monitor is running
Retrieving MSE Services status.
[main] INFO com.cisco.ciscossl.provider.ciscojce.CiscoJCEProvider - CiscoJ configured for FIPS mode
[main] INFO com.cisco.ciscossl.provider.ciscojce.CiscoJCEProvider - CiscoJCE turning on FIPS...
[main] INFO com.cisco.ciscossl.provider.ciscojce.CiscoJCEProvider - CiscoJCEProvider version 2.0520150519 loading...
[main] INFO com.cisco.ciscossl.provider.ciscojce.CiscoJCEProvider - Executing Java version = 1.7.0_45
MSE services are up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 8.0.130.0
Health Monitor Ip Address: 172.20.x.x
High Availability Role: 1
Hw Version: V01
Hw Product Identifier: AIR-MSE-VA-K9
Hw Serial Number: mseprimary_d
HTTPS: null
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 8.0.1.108
Admin Status: Enabled
Operation Status: Up
Service Name: WIPS
Service Version: 3.0.8191.0
Admin Status: Disabled
Operation Status: Down
Service Name: Mobile Concierge Service
Service Version: 5.0.1.23
Service Name: CMX Analytics
Service Version: 3.0.1.73
Service Name: CMX Connect & Engage
Service Version: 1.0.0.32
Service Name: HTTP Proxy Service
Service Version: 1.0.0.1
Server Monitor
Server start time: Sat Apr 23 00:57:50 PDT 2016
Server current time: Sat Apr 23 10:25:16 PDT 2016
Server timezone: US/Pacific
Server timezone offset (mins): -480
Restarts: 4
Used Memory (MB): 178
Allocated Memory (MB): 2970
Max Memory (MB): 4454
DB disk size (MB): 5245
Active Sessions
Session ID: 2595
Session User ID: 1
Session IP Address: 172.20.x.x
Session start time: Sat Apr 23 01:01:20 PDT 2016
Session last access time: Sat Apr 23 10:23:06 PDT 2016
Default Trap Destinations
Trap Destination - 1
Last Updated: Sat Apr 23 04:01:55 PDT 2016
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wired Clients): 0
Active Wireless Clients: 0
Active Tags: 0
Active Rogue APs: 0
Active Rogue Clients: 0
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients, Tags) Limit: 100
Active Sessions: 1
Wireless Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Locally administered clients Not Tracked due to filtering: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) Not Tracked due to the limiting: 0
]0;
[root@mseprimary ~]# gethainfo
Health Monitor is running. Retrieving HA related information
Base high availability configuration for this server
Server role: Primary
Health Monitor IP Address: 172.20.x.x
Virtual IP Address: 172.20.x.x
Version: 8.0.130.0
UDI: AIR-MSE-VA-K9:V01:mseprimary_d
Number of paired peers: 0
Any help or solution at the earliest would be of great help..
Mugilan S
Solved! Go to Solution.
05-07-2016 11:54 AM
You might be hitting CSCux48283:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux48283/?referring_site=bugquickviewredir
Try the workaround in the bug. In my case, I had PI and the MSE on the same subnet so there was no firewall issue. I changed the password for PI in the MSE (even though I had the correct password and I was able to add the MSE to PI). After that change and restarting the service, I was able to get into the HA config in PI.
05-07-2016 11:54 AM
01-26-2019 06:51 PM
so what password you change ? pi or mse ?
and how restart the service ?
05-10-2018 12:57 PM
Check the health monitor address on the secondary. If that doesn't match the IP that you are wanting to use for the health monitor, for example it's defaulted at 1.1.1.1 If this is the case, re-run setup on the secondary, and revisiting the role. Select secondary again, and when the information is reapplied, Prime will be able to configure the two to communicate as desired.
