12-02-2019 03:48 AM - edited 07-05-2021 11:22 AM
I have just upgrade our controller to 8.5.151.0 and some APs are joined but appear to be reporting the older version as the running image. Looking on the AP I see the following:
show ver
AP Running Image : 8.3.140.0
Primary Boot Image : 8.5.151.0
Backup Boot Image : 8.3.140.0
But according to the book parameters it should be usng the primary (8.5.151.0)
show boot
BOOT path-list: part1
Console Baudrate: 9600
Enable Break: yes
Manual Boot: no
Memory Debug: no
more flash part1_info.ver
image_family: ap1g4
ws_management_version: 8.5.151.0
info_end:
more flash part2_info.ver
image_family: ap1g4
ws_management_version: 8.3.140.0
info_end:
It appear to be only affecting 1800/2800/3800 models (and not all of them).
Is this normal behaviour? I was under the impression it was not possible for an AP to join with a different version.
Solved! Go to Solution.
12-03-2019 03:05 AM
12-02-2019 04:09 AM
- Try rebooting the affected AP's >from the controller< ; check if the problem persists afterwards.
M.
12-02-2019 08:31 AM
12-02-2019 11:09 AM
12-02-2019 01:41 PM
12-02-2019 02:03 PM
Thanks for all the feedback. To answer some of the questions/provide feedback.
II'm not sure if this is just a cosmetic issue but other APs seem to switch over without issue and I only noticed it by chance while looking into a another problem with 2800/3800's not authenitcating clients.
12-02-2019 03:38 PM
12-03-2019 03:05 AM
