Hi all,
Does the CSR support L2Tpv3?
Specifically we want to terminate Meraki SSID L2TPv3 tunnels into a central location. If a CSR doesn't support this what would anyone suggest as a viable option?
Thanks in advance
Take a look at EOGRE.
-If I helped you somehow, please, rate it as useful.-
The restrictions under https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cether/configuration/xe-16/ce-xe-16-5-book/ce-L2-EoGRE.pdf say that L2 EoGRE is not supported on the Cisco CSR1000V platform.
Is there another type of EoGRE?
