03-19-2013 06:31 AM - edited 07-03-2021 11:45 PM
Hi:
i have two 1262
one is join ok
but one join loop
03-19-2013 06:36 AM
When I run into an issue like that, I usually would either upload a different recovery image or concert it to autonomous and then back to lightweight.
03-19-2013 06:44 AM
Wow. it seems the abnormal behavior with the AP join issues are more common than what one can expect.
Rating useful replies is more useful than saying "Thank you"
03-19-2013 06:37 AM
Make sure the date and time is correct on the controller.
I can see from your screenshot that the AP goes to CFG state which means the join is OK.
Please check again and provide txt format, not screenshot of the logs.
Check also the logs and traplogs on the controller if it tells anything.
Amjad
03-19-2013 06:46 AM
Amjad,
I have seen AP's get into the CFG and then it fails to complete and goes back in a loop. Usually it's a corrupted recovery image and replacing that has always been the fix for me, since I play around with beta codes and that seems to mess up my AP's:)
03-19-2013 06:51 AM
I did that once with 1522 AP that took my whole day tryin got understand where the problem is. But the recovery image solved that. But it is a headahce to console to an outdoor AP. Those who deal only to indoor APs should know they are lucky. ;-)
03-19-2013 06:38 AM
Is is the conversion process
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
03-19-2013 06:51 AM
thanks
