Cisco Community Designated VIP Class of 2020
2965
LAP1242 cannot join the WLC2500
I have some LAP1242 which by mistake were bought for Mesh. I am trying to convert them to LWAPP so what I did first was to convert them to Stand Alone then to LWAPP but I cannot get the AP to join the WLC and sends several error logs.
I attached some logs taken from AP and WLC so that you can figure out what's going on.
I wonder if I have to remove anything from flash either on SA or LWAPP mode (I know that in some cases you have to delete privete-config in order to avoid the AP taken previous configurations). By the way I think I had never seen this c1240-k9w8-mx.124-25e.JA2 on an AP IOS before, I wonder if it has to do with the mesh thing.
Thank you!
27 REPLIES 27
Hall of Fame Master
Re: LAP1242 cannot join the WLC2500
I can't view your files from this iPhone app. Have you looked at this doc. It explains how to upload different codes onto an access point.
https://supportforums.cisco.com/docs/DOC-14960
-Scott
I have done that process thousands of times but this time the APs came with an IOS for mesh and once it is back in LWAPP it still shows the mesh stuff in the flash.
Flash Stand Alone:
Directory of flash:/
   17  drwx         320  Jan 01 1970 00:05:46 +00:00  c1240-k9w7-mx.123-8.JEA3
    7  -rwx          62  Nov 14 2012 14:35:46 +00:00  mesh_cfg.txt
    8  -rwx        6168  Nov 14 2012 14:45:49 +00:00  private-multiple-fs
    9  -rwx       97561  Nov 14 2012 15:15:44 +00:00  event.log
   10  drwx         256  Jan 17 2013 17:52:05 +00:00  c1240-k9w8-mx.124-25e.JA2
   15  -rwx          36  Nov 14 2012 14:35:46 +00:00  mesh_port_cfg.txt
   16  drwx           0  Nov 14 2012 14:35:49 +00:00  configs
    4  -rwx         266  Jan 01 1970 00:05:52 +00:00  env_vars
Flash LWAPP:
    2  -rwx         318   Mar 1 2002 00:00:06 +00:00  env_vars
    3  -rwx        6168  Nov 14 2012 14:36:04 +00:00  private-multiple-fs
    4  drwx         128  Jan 16 2013 15:11:30 +00:00  c1240-rcvk9w8-mx
    8  -rwx           5  Jan 16 2013 15:11:56 +00:00  private-config
   19  drwx         256  Jan 17 2013 21:12:38 +00:00  c1240-k9w8-mx.124-25e.JA2
   10  -rwx           0  Nov 14 2012 14:36:05 +00:00  config.txt
Logs from AP
Jan 17 18:28:15.377: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 17 18:28:15.382: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 17 18:28:16.407: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 17 18:28:17.407: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jan 17 18:28:24.810: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 17 18:28:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.2 peer_port: 5246
*Jan 17 18:28:26.002: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 17 18:28:26.007: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 17 18:28:27.187: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jan 17 18:28:27.322: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 17 18:28:27.400: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Jan 17 18:28:27.401: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Jan 17 18:28:27.403: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 17 18:28:27.404: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Jan 17 18:28:27.404: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
*Jan 17 18:28:27.405: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan 17 18:28:27.330: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 17 18:28:27.335: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Jan 17 18:28:27.340: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 17 18:28:27.409: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.2 peer_port: 5246
*Jan 17 18:28:27.410: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.2
*Jan 17 18:28:27.413: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.1.2
*Jan 17 18:28:27.413: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.2:5246
Logs from WLC
*spamApTask0: Jan 17 15:18:25.695: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 The system could not send join reply, AP authorization failed; AP:6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:18:24.273: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 The system could not send join reply, AP authorization failed; AP:6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:18:12.435: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 The system could not send join reply, AP authorization failed; AP:6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:18:11.023: %LWAPP-3-RADIUS_ERR: spam_radius.c:137 The system could not send join reply, AP authorization failed; AP:6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:16:18.080: %LWAPP-3-ECHO_ERR: spam_tmr.c:1381 Did not receive heartbeat reply; AP: 6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:13:49.192: %LWAPP-3-RX_ERR3: spam_l2.c:440 The system has received LWAPP packet with invalid sequence number (got 3expected 4) - from AP 6c:20:56:e8:ea:f4
*spamApTask0: Jan 17 15:13:45.935: %LWAPP-3-PAYLOAD_MISSING: spam_lrad.c:5730  Join request does not contain BOARD_DATA payload
Hall of Fame Community Legend
Can you please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  AP:  sh version; and
3.  AP:  sh inventory
1.-
Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.111.3
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 15.0
Build Type....................................... DATA + WPS
System Name...................................... Lab-HREAP
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.2
Last Reset....................................... Power on reset
System Up Time................................... 0 days 6 hrs 15 mins 24 secs
System Timezone Location......................... (GMT -6:00) Central Time (US and Canada)
Configured Country............................... MX  - Mexico
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +32 C
External Temperature............................. +34 C
Fan Status....................................... 3344 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ D0:C2:82:DE:88:E0
Maximum number of APs supported.................. 5
2.-
ap#show version
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
ap uptime is 0 minutes
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
cisco AIR-LAP1242AG-N-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1646B0F6
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 6C:20:56:E8:EA:F4
Part Number                          : 73-13785-01
PCA Assembly Number                  : 800-37050-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16420QSU
Top Assembly Part Number             : 800-29151-03
Top Assembly Serial Number           : FTX1646B0F6
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-N-K9
Configuration register is 0xF
3.- It doesn't give an output for show inventory
Hall of Fame Master
Have you tried to delete that image and tftp the new image?
-Scott
That's what you do when convert from SA to LWAPP and vice versa you tftp a different image.
What I just did was from stand alone I delted "privet-config", "mesh_cfg.txt", "mesh_port_cfg.txt", and tried to delete also the c1240-k9w8-mx.124-25e.JA2. Then I converted to LWAPP but I had the same result.
I wonder if it has something to do with the fact that these APs come with mesh from factory?
Thank you!
Hall of Fame Master
You need to tftp this file to your 1242 and set it to boot from it. Then delete the other image before you reboot.
WIRELESS LAN LWAPP RECOVERY
c1240-rcvk9w8-tar.124-10b.JDA.tar
-Scott
So I have to convert to stand alone again, then tftp this image? I don't know how to tftp something to a LWAPP.
Hall of Fame Master
If you have it as an autonomous ap just connect it to the network and let it get an IP address. You can the use the archive download-sw /o /r tftp:///
-Scott
Hall of Fame Master
The link I posted earlier has directions with other ways of doing this
-Scott
Highlighted
Hi Scott,
Unfortunately it didn't work either and I still have the same files in the flas, the ones related with mesh.
    3  -rwx        6168  Jan 18 2013 22:23:25 +00:00  private-multiple-fs
   10  drwx         128   Mar 1 2002 00:03:20 +00:00  c1240-rcvk9w8-mx
    4  drwx         256  Jan 18 2013 22:14:31 +00:00  c1240-k9w8-mx.124-25e.JA2
    7  -rwx           5   Mar 1 2002 00:02:42 +00:00  private-config
    9  -rwx       93536  Jan 17 2013 21:55:15 +00:00  event.log
    5  -rwx          63  Nov 14 2012 14:35:46 +00:00  mesh_cfg.txt
    8  -rwx         325  Jan 18 2013 22:21:31 +00:00  env_vars
    6  -rwx          36  Nov 14 2012 14:35:46 +00:00  mesh_port_cfg.txt
Beginner
I just run into this threat searching for an answer to the problem I have had for quite some time. The problem you are describing is exactly the same as my problem. We also have LAP1242, WLC2500 and the same error messages.
The last post is from 18th of Jan... I was wondering if you had any luck solving this issue since then?
Arjen
Hall of Fame Master
I have a 1242 and 1131 and have no problem converting these to lightweight or to autonomous. I guess you can start a new thread and post the output if what you see.
-Scott
Beginner
Hello Scott,
Thanks for your prompt reply!
Are your 1242 and 1131 connected to WLC2500 (WLC2504) as well? If so, what firmware does your WLC have and which one on your 1242?
I hooked into this threat because AP, WLC and errors are exactly the same. Just avoiding different threats for the same issue/problem.
Content for Community-Ad
August's Community Spotlight Awards
