large venue WIFI
What are the best AP's to use in a concert hall type venue with a large nunmber of client users and how do I make it so that they are spread across the AP's and not just filling certain ones up?
25 Replies 25
Scott Fella
Not knowing how the venue is and really how big, it would be pretty hard to answer your question. If you think you will have alot of multipath, then maybe look into the 1252 or the 1142. Again, is it the best ap you are looking for or maybe it should be what antenna should I use. One thing to understand is that many users out there have only 2.4ghz enabled for iphones, etc. So now it comes down to how many 2.4ghz radios can I have in an area without having too much interference. This can only be determined by a wireless site survey. The 5ghz side, you have more than 3 channels to play with so you can have more radios in a given area than you can in the 2.4ghz side. Also, the mounting of the ap's.... is it going to be 50+ feet up in the air or lower... this will affect your signal propagation. There is too many things to look at to see if this is even possible, especially if you plan on supporting 100+ devices.
-Scott
The venue is the size of a movie theatre but used for concerts and will have maybe 200 users across the area. The AP's will be mounted about 20 feet high, my question was more how do I get the users in the area to spread out across the AP's the main clients will be on 2.4ghz. I was thinking of using 1240's as I have heard they give better RF coverage etc even on a 802.11g network has anyone used them for 802.11g in partyicular?
sorry for 1240 replace with 1250 slip of fingers.
Just to muddy the waters some more we are thinking of using 1250's to increase the RF footprint and throughput.
This will be mainly on 802.11g network is the Cisco hype true, do they increase those qualities or should we just stick with 1242's and lastly would we get away with less 1250's than 1242's due to a larger coverage area.
thanks
Cancel the 'how many' would we use question in comparison to 1242's as Cisco doctrine is replace 1:1 apart from in a full 802.11n environment answers to the other queries gratefully accepted.
Per Cisco and and I agree to this is it is a one to one replacement. So I you had a 1242 deplyment, you can use the same locations if you were to replace the 1242 with 1252's. The issue would be how much interference you will have due to overlapping channels. Aggressive load balancing can be enabled on a wlc and from another post, ap's that have 12 users will try not to respond to beacons from the 13th device. If the client doesn't associate with another ap, that ap will allow that 13th device.
-Scott
ericgarnel
Level 7
Level 7
I deal with this issue on a daily basis.
We have seen as many as 1755 simultaneous users on our wireless and expect to go over 2000+ simultaneous users in early March.
We use the 1252s in a high density deployment.
For dense crowds, such as large breakouts, key note speeches, etc. we deploy "field kits" that consist of either 1252 or 1242 APs, some of which are mounted on tripods or placed below chairs. We also will use directional antennae to help steer the signal.
People aka "bodies of water" absorb rf which we use to our advantage to pack in more APs in a given area. We also adjust the user counts per AP as well as "steer" 802.11a/b/g clients towards the 802.11a side by tweaking the 802.11.. signal properties.
Be careful of how you handle throughput, you do not want to have a great wifi signal, but clog your internet pipe.
A survey is great, but when you pack a room full of people, chairs, truss, etc, the dynamics change drastically.
Hi thanks for the great responses much appreciated
Leo Laohoo
Alot of good points above. Before you make a 1:1 replacement, make sure you have a Wirelss Site Survey using the AP or your choice.
The 1250 has a new "little brother" which can also do Draft N 2.0, the 1140. Unlike the 1250, the 1140 can operate using standard PoE but the range of the radios have been curtailed. The 1250 "can" work on standard PoE (either removing one of the radio modules or cranking down the power). To get the 1250 to operate at full power (radio transmission and range), you either put a power injector or use a switch that will support Enhanced PoE (3560-E/3750-E, Sup720).
The difference between the two is the suitability of a location. The 1140 is designed for office environment (cubicles, offices, compactors, etc.) while the 1250 is designed for warehouse environment (large open space).
Here are some options you may want to consider:
Cisco Aironet 2.4 GHz and 5 GHz Antennas and Accessories
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b.html
Cisco Aironet Antennas and Accessories Reference Guide
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
Another issue to consider is the wired infrastructure that supports the wireless.
We are pushing 3560-E series switches out not only to support the power requirements, but also to provide sufficient backplane and bandwidth to support and scale for the 1252 APs.
Here is a great article in the cisco ip journal that outlines some the needs for the newer wireless
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_11-4/114_wifi.html
ericgarnel
Level 7
Level 7
Here are a few of our "field kits"
Eric
thanks where did you get the stands etc if that isnt a silly question
Mick
Mick,
the shorter stands are sign easels that have been left over from various shows. The tall pole is a leftover work-light pole that we cut the light off of. The pole is handy as it can extend to 11 feet. You can get the poles at many hardware stores.
I also use mic stands as well, they work great with 1252s
Things that come in handy:
PVC (outdoor conduit cuts & drills easily)
zip ties: cannot ever have enough zip ties
velcro: fabric of the eighties
miscellaneous bolts, screws. most of which came with various network devices.
switch or router rack mounts- very handy
hose clamps - awesome for mounting to rails!
Moly bolts
a bad a$$ drill with lots of bits.
I will also use sand bags, cinder blocks, etc to lock APs to using cable locks for under chair deployments.
The field kits are used for high-density breakouts & sessions where ceiling or wall mounted APs cannot provide adequate coverage.
"impressive" is an understatement!!! Wicked!
