ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
LDAP client auth
I've searched the internet but the examples I've found use certificates or web auth.  I'm trying to get users to authenticate using their LDAP credentials on a new SSID.
I have the LDAP server set up on the controller but I'm still having troubles getting authentication to work.
I'd like to bypass using ACS and have the controller talk directly to the LDAP server.
In our environment we have the following:
Two WiSM controllers in separate data centers
4402 guest controller (in production now)
5508 guest controller (being installed now)
All controllers running 7.0.235.3
ACS 4.2
NCS 1.1.1.24
1 ACCEPTED SOLUTION
Highlighted
LDAP client auth
that should do. on the client make sure you uncheck the box to 'validate server certificate' as well.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
14 REPLIES 14
Highlighted
LDAP client auth
So you are looking at the guides for Local EAP?  or is this for guest users?
HTH,
Steve
Highlighted
Beginner
LDAP client auth
These will be contractors that are BYOD but do have AD login credentials.
Highlighted
LDAP client auth
So you have the WLC configured for Local EAP/PEAP?
HTH,
Steve
Highlighted
Beginner
LDAP client auth
I have the LEAP profile set up and chosen on the WLAN tab.
Highlighted
LDAP client auth
I would set it for PEAP vs LEAP.  Not all supplicants support LEAP and it's vulnerable.
HTH,
Steve
Highlighted
Beginner
LDAP client auth
Do you have a link or anything about setting that up?  Does it require certs?
Highlighted
LDAP client auth
you should just need to check the PEAP box and not the LEAP box.
as for certs, just on the WLC and it will be there already.
HTH,
Steve
Highlighted
Beginner
LDAP client auth
So then I have to choose "
Highlighted
LDAP client auth
not required...those are for TLS.  so you shoudl be able to uncheck those boxes
HTH,
Steve
Highlighted
Beginner
LDAP client auth
They were unchecked...
Here is what I have:
L2 security
WPA+WPA2 selected.
Checkbox for WPA2 policy WPA2 encryption AES
Auth Key MGmT 802.1x
AAA Sever tab
LDAP server selected
Local EAP Authentication checked
EAP Profile Name - Test
Local EAP Profile - Test
PEAP checked, nothing else
Authentication Priority - LDAP
Is there anything else I'm missing?
Highlighted
LDAP client auth
HTH,
Steve
Highlighted
Beginner
LDAP client auth
I think I got it... had to set up the network profile in Windows.
I'm a total n00b at this so thanks for your help!
Highlighted
LDAP client auth
no worries, that's why we are here!
HTH,
Steve
Highlighted
Beginner
LDAP client auth
Ok, so now the problem I ran into is that when I change priority order -> local auth to LDAP, it breaks our 7925 wifi phones.  Even if I have LDAP and Local in the box, if I change the order to LDAP/Local it breaks the phones but LDAP works.  If I change it to Local/LDAP the phones work again but LDAP doesn't.
The phones are using EAP-Fast.  Any ideas?  Do I need to change the auth method of the phones?
Content for Community-Ad
