04-04-2017 02:57 AM - edited 07-05-2021 06:47 AM
I have around 10 Cisco AIR-AP1042N-E-K9 that are already attached to my WLC 2504.
My first question is: the way I can check how many clients/users are connected to one of the 10 AP
My second question is: Is there a limit max of users per AP. I've read on some forum that for design you have to count 30users per AP. But I want to confirm for my version of AP above is there any limit max of users per AP to get an optimal performance in term of speed rate?
Augustin ANDRIA
04-04-2017 07:00 AM
Go to WLAN > SSID Name > Advanced tab.
There is a box on the left-hand corner to limit the amount of Maximum Allowed Clients Per AP Radio. **** By default it is set to 200.
My first question is: the way I can check how many clients/users are connected to one of the 10 AP:
If you are using the latest SW version on WLC then you cna check by going to Wireless > All APs, on this page you can see the number of clinets to each AP.
Rule of thumb is 25 but if its just web and email traffic you can have more.
Dont forget to rate helpful posts
04-05-2017 02:24 AM
(Cisco Controller) >show client ap 802.11a ?
<Cisco AP> Enter 'all' or the name of the Cisco AP.
04-06-2017 05:09 AM
Will check it by CLI also
04-06-2017 05:08 AM
Thank you,
I will give it a try
04-07-2017 01:29 AM
Also for high density setups check out this document:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10981/design_guide_c07-693245.pdf
One of the most important parts is to disable low Data Rates for greatly improved performance (extremely important if you have many SSIDs configured).
08-10-2023 11:14 AM
I realize this thread is old - but just to add (since I was just looking at the difference between the WLANs -> SSID -> Advanced option and the WIreless -> RF Profiles -> <profile> -> High Density -> Maximum Clients option....
They look to be the same according to the 8.5.x firmware Configuration guide.
Cheers,
-Ben
