Link speed on 2602 in Bridge mode
larsthobiasen
I need to create a number of bridges on a installation, where i need to use some exsisting 5GHZ antennas
I can only connect one 5Ghz antenna on each Access-point.
What is the Max link speed then using a single Antenna - in the best signal senario?
/Lars
Stephen Rodriguez
with one antenna, you'll only get one Spatial Stream, so you will only get ~74Mbps a bit more if you do channel bonding.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
