LMS and WLC compatibitlity
Prasan Venky
Level 3
Level 3
Hi all,
We have LMS 3.2.1 and WLC version 7.0.116. I want WLC syslog to be managed by LMS. How can i acheive that..? Any special package need to applied for LMS ..? Please help.
Scott Fella
Well you can always point WCS syslog to any syslog server. Why not just look at Prime infrastructure. It is the new WCRs/NCS platform with LMS built in.
-Scott
Scott Fella
-Scott
Hi Scott,
Thanks for your reply. Currently we are running with LMS only. In future we would possibly convert it into PI.
Just speak with your SE. PI is great for the wireless side but isn't 100% migrated with LMS but should be soon.
-Scott
Abhishek Abhishek
Hello Prasan,
As per your query i can suggest you the following solution-
Please refer to the LMS and WLC compatibility guide for managing the WLC syslog through LMS.
For more information refer to the link-
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Hope this will help you.
