08-29-2013 05:23 AM - edited 07-04-2021 12:43 AM
i got a problem with changing 1552e firmware to autonomous. i made many times other ap' s firmware change but now something wrong. i installed the tftpd server to machines it s working ok.image is :c1520-k9w7-tar.default. my pc ip address 10.0.0.2/24. pushing to reset button and release and 1552 loading default config. tftpd server doen t create any log. the ap i think doesn t look a tftp server. anyone has any idea about the issue? thanks.
08-29-2013 12:18 PM
Hi Ilkay,
Were you holding the reset button down for at least 20-30 seconds? An easier way may be to console directly into the device and issue the following command through CLI:
debug capwap console cli
archive download-sw /force /over tftp://
Cheers,
Erwin
______________________________________
How helpful was I? Don't forget to rate me when you have the chance!
08-30-2013 01:38 AM
%Error opening tftp://10.0.0.2/c1520-k9w7-tar.152-4.JA1.tar (Timed out)
mostly i want to kick cisco products (:
08-30-2013 12:44 AM
thanks erwin, i m trying to archive command but its giving error opening tftp server timeout. Tftp server open and running . Ap ping to tftp server. netstar -a saying port 69 ok. do you have any idea?
Sent from Cisco Technical Support Android App
08-30-2013 11:10 AM
the ap, its not looking any tftp or ftp protocol. same error for both protocol.
09-03-2013 08:10 AM
Ilkay,
Is the tftp server pingable from the AP itself? You may have to assign static address information if you are plugging the AP directly to your laptop:
capwap ap ip address
capwap ap ip default-gateway
Cheers,
Erwin
09-04-2013 06:24 AM
thx erwin, i did it still same...
09-05-2013 05:18 AM
What TFTP server are you using? I know their are issues with Aironet APs and OS X built in Tftp server.
09-06-2013 12:58 PM
here is the result when i was try downgrade from wlc :
%Error opening tftp://10.0.0.3/c1520-k9w7-tar.152-4.JA1.tar (Timed out)
archive download: takes 62 seconds
i upgraded the wlc ios over same tftp server. i want to hammered the fucking ap!!!
09-06-2013 01:43 PM
hi everyone,
i have a new issue. my tftp server ping to wlc. wlc ping to tftp server. 1552e ping to wlc wlc ping to 1552e. here is the issue ap doesnt ping to tftp server and tftp server doen t ping to 1552e. anyone has any idea ?
09-07-2013 01:38 AM
problem solved with the wlc 2504. but i have new advantures. cisco entertainment company. new issue here. i m configuring the ap but when i restart the ap configuration lost. cool huh!
09-07-2013 05:43 AM
Make sure the ap is in a REG state before you configure the AP.
09-07-2013 06:21 AM
sorry scott i didn t update new issues resolve the configuration error with config.txt. now the ap not broadcast ssid...
here is the config :
! ! Last configuration change at 14:46:21 UTC Sat Sep 7 2013 version 15.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname T-ISKELE ! ! logging rate-limit console 9 no logging console enable secret 5 $1$Ngui$7VOfhU.knttlfvsQSYkNw/ ! no aaa new-model no ip cef ip name-server 192.168.10.1 ! ! ! ! dot11 syslog ! dot11 ssid AP1 authentication open authentication key-management wpa version 2 wpa-psk ascii 7 07192E484F0F160B121C0E1824787B757B ! dot11 ssid ssid-string guest-mode ! ! dot11 guest ! ! ! username Cisco password 7 02250D480809 ! ! bridge irb ! ! ! interface Dot11Radio0 no ip address ! encryption mode ciphers aes-ccm tkip ! ssid AP1 ! antenna gain 128 speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio1 no ip address ! encryption mode ciphers aes-ccm tkip ! ssid AP1 ! antenna gain 128 peakdetect no dfs band block speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. channel dfs station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface GigabitEthernet0 no ip address duplex full bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface GigabitEthernet1 no ip address duplex full bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface GigabitEthernet2 no ip address duplex full bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface GigabitEthernet3 no ip address duplex full bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface BVI1 ip address 192.168.10.202 255.255.255.0 ipv6 address dhcp ipv6 address autoconfig ! ip default-gateway 192.168.10.1 ip forward-protocol nd ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 login local transport input all ! end
09-07-2013 06:28 AM
i saw my mistake resolve the problem... (:
10-30-2013 04:36 PM
Please refer to the datasheet -
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps11451/data_sheet_c78-641373.html
