LWAPP / WiSM and non-global WLANs
mduling
How would I disallow LWAPP APs (managed by a WiSM) in a remote areas from supporting my guest access WLAN, without diabling the guest access WLAN globally? Right now I have the same WLANs defined on both WiSM controllers and a centralized WiSM at the core for the campus. Thanks.
dholder
On the AP configuration on the controller:
WLAN Override
WLAN Override Disable Enable
Change the WLAN override to ENABLE and select the SSID's that you want to be on that AP.
Hope that helps.
Dave
That did it. Thanks!
lynne.meeks
How can one verify that a WLAN is NOT active on the APs it shouldn't be on?
I have run the WLAN override on the WCS, which is reported to be successful, yet the WLAN that should only be on TWO APs is showing up on other APs. (not to mention that that SSID is not supposed to be broadcast anywhere!)
When I look at the APs on the controller there is no indication of which WLANs are active on the AP.
How can I verify which WLANs are actually active on any particular AP?
Thanks-
Lynne
