12-12-2018 05:46 PM - edited 07-05-2021 09:35 AM
Hi Guys,
having a problem with Macbook OSX devices, connect to the wireless network, receive an IP address, get redirected to the web login page
submit credentials and then nothing happens, keeps spinning wheels and then another blank tab opens,
checking the logs on ISE there is nothing and the request is not hitting ISE
any idea.
12-12-2018 05:59 PM
What version of ISE are you running as well the patch version, also what model WLC and version code are you running?
12-12-2018 06:00 PM
ISE 2.2
WLC WISM2 running 8.1
12-12-2018 06:08 PM
12-12-2018 08:20 PM
