12-05-2011 11:35 PM - edited 07-03-2021 09:11 PM
Hi all,
I have a customer buys 12 x WISM and build up a mobility, when I add the final WLC to mobility, it prompts that there mobility group has reached the max of mobility member, but the total member is 23, according the configuration guide, it should be allow to 24 member, do I hit some bug? My using version is 7.0.98.0, thanks.
12-06-2011 06:02 AM
You should be able to have 24.. that is including the WLC itself on the list I believe. If you do a show mobility summary from the CLI, does it only show 23?
12-07-2011 02:42 AM
Here is the output from console:
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xd4f0
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 23
Mobility Control Message DSCP Value.............. 0
12-07-2011 05:08 AM
Okay so that also verifies 23. Does this happen with all your WLC's by chance. I would just open a TAC case to see what they say.
Sent from my iPhone
02-15-2012 04:55 PM
Here is the finding of this case:
CSCtj97304 JMR1:Not able to add 24th mobiity membr when system mac is deleted/added
Symptom:
Not able to add the 24th member in the mobility group
Conditions:
When the entry with the system mac is deleted and added back.
Workaround:
Don't delete/add entry with the system mac
The fix has been integrated in 7.0.116.0 or later.
02-15-2012 07:31 PM
Thanks for the follow up!
