07-24-2012 05:21 AM - edited 07-03-2021 10:26 PM
Is there any specfications I should be looking for when buying a Microwave oven. The question being is one better then another for interfernce on my WLAN?
07-24-2012 07:05 AM
if you are looking for one that will not interfer, it probably won't be an issue. Most times microwaves interfer with the WLAN is when they get a bit older and their sheilding is failing.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
07-24-2012 07:07 AM
Hi Tom,
I always recommend customers get enterprise grade mw ovens. The seals are stronger and dont leak as much. The walmart mw, for example, arent made to be opened and closed 30x times a day and seals become worn very quickly. You can do a quick google search and fine a number of enter kitchen warehouses that sell these types of mws.
I might also recommend getting the lowest watt mw possible. No need to get a 1000 watt if it isnt needed.
I hope this helps.
