02-06-2013 03:06 PM - edited 07-03-2021 11:29 PM
Hello group,
We are currently upgrading from WISM-1's to individual 5508 WLC's. Is it possible to export the config from controller on the WISM to the 5508?
02-06-2013 03:29 PM
You can search this forum as to how other have gone about this... I will try to sum it up.
Make sure the existing WLC and the new WLC is on the same code... has to be 7.0.x
config mgmtuser add
CISCO TAC DOES NOT SUPPORT THIS
Scott
Help out other by using the rating system and marking answered questions as "Answered"
02-06-2013 03:31 PM
Thanks for the answer, Scott. I will give this a try.
02-06-2013 03:33 PM
It works.... just give it a try because you can always factory default the 5508. The management username is what gets corrupted when you upload it when its hashed.
Scott
02-06-2013 03:44 PM
Appreciate the help Scott. Currently running backups of both controllers, will import configs into text file and edit and upload.
02-06-2013 03:54 PM
Let me know if it works for you.
Scott
05-09-2016 09:15 PM
Hi Scott Fella,
We need to do migration from WISM to WLC 5520, can you help me on the same. As I checked wlc 5520 last image support is 8.x and WISM is 7.x , in that case if we try to export the configuration from WISM and import it to WLC 5520 , so it will support ?
09-06-2013 02:14 AM
Additions to can AP lic transfer is also supported from WiSM to 5508 Controller.
Current WiSM-1 is with ver 7.0.98
Also if it is not possible then can we transfer the WiSM1 image with all AP lic to a VM Machine and then upgrade it to 7.4
