Mobile Devices Support
DivZ
I am looking for a reference document for the type of devices that are supported under 5Ghz. We are using a 5500 WLC and 3600 WAPs. Lot of users cannot connect to network via mobile devices. Is there a reference doc from cisco which i can use to inform them?
2 Accepted Solutions
Leo Laohoo
Mobile devices?   Not all smartphones or tablets support 802.11a.
I was looking for a list of mobile devices which are not supported by 5Ghz WAPs.
No way you can find that here.
You need to contact the manufacturer of your mobile devices and ask them yourself or look at the product specification sheet.
5 Replies 5
Scott Fella
Any device that has a 5ghz radio is supported on any 5ghz capable AP. you need to look at your configuration as that most likely will be your issue.
-Scott
I do understand that. I was looking for a list of mobile devices which are not supported by 5Ghz WAPs.
thanks for your reply! got it!
Leo Laohoo
