09-11-2012 01:55 AM - edited 07-03-2021 10:38 PM
Can I configure a mobility groups between 2106 Wireless LAN Controller and 5500 Wireless LAN Controllers?
Thanks.
Solved! Go to Solution.
09-11-2012 02:06 AM
Patricia,
Please mark the discussion as "Answered".
Amjad
Rating useful replies is more useful than saying "Thank you"
09-11-2012 01:57 AM
Yes you can. Remember that the 2106 can't be an anchor though.
09-11-2012 02:00 AM
Here is a link that should help
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp102617
09-11-2012 02:04 AM
Thank you!!
09-11-2012 02:06 AM
No problem...
09-11-2012 02:06 AM
Patricia,
Amjad
09-11-2012 02:12 AM
It was my first question on this forum. Can you remind me please how to mark it as answered?
09-11-2012 02:19 AM
Hi Patricia:
Welcome to the forums then.
Actually Scott's answer was the correct one. Not mine. So just to appreciate Scott's efforts (Thanks Scott) try please to mark his answer as the correct answer. Just below his answer there is a button to mark it as correct answer.
Come back soon.
Amjad
09-11-2012 09:49 AM
Pat,
Do you plan on anchoring a controller in the DMZ? If you are you should consider putting the anchor in a different mob group to limit the amount and unneeded mobility mesaages getting sent to the DMZ.
__________________________________________________________________________________________
