Mobility groups between WLC 2106 & 5500
patriciasimo
Can I configure a mobility groups between 2106  Wireless LAN Controller and 5500 Wireless LAN Controllers?
Thanks.
Patricia,
Please mark the discussion as "Answered".
Amjad
Rating useful replies is more useful than saying "Thank you"
8 Replies 8
Scott Fella
Yes you can. Remember that the 2106 can't be an anchor though.
-Scott
Scott Fella
Here is a link that should help
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp102617
-Scott
patriciasimo
Thank you!!
No problem...
-Scott
Patricia,
Amjad
It was my first question on this forum. Can you remind me please how to mark it as answered?
Hi Patricia:
Welcome to the forums then.
Actually Scott's answer was the correct one. Not mine. So just to appreciate Scott's efforts (Thanks Scott) try please to mark his answer as the correct answer. Just below his answer there is a button to mark it as correct answer.
Come back soon.
Amjad
Pat,
Do you plan on anchoring a controller in the DMZ? If you are you should consider putting the anchor in a different mob group to limit the amount and unneeded mobility mesaages getting sent to the DMZ.
__________________________________________________________________________________________
