05-12-2011 01:47 AM - edited 07-03-2021 08:11 PM
I am trying to upgrade an MSE from version 6 to 7.0.201.204. I am able to copy across all the files and have tried using WCS and FTP for the CISCO-MSE-L-K9-7-0-201-0-64bit.bin file but the installation procedure always fails. Is anyone else haveing the same issue?
I will dowload all the images again tonight. Is there a way to delete the images from the /opt/installers/ directory?
Also the upgrade procedure in the 7.0.201.204 is pretty bad, there is no detail in any of the steps. Has anyone found a better procedure? (keeping in mind this release is different to older ones)
Here is output from the upgrade -
[root@SDC-MSE-01 installers]# dir
CISCO-MSE-L-K9-7-0-201-0-64bit.bin database_installer_part3_4.zip
database_installer_part1_4.zip database_installer_part4_4.zip
database_installer_part2_4.zip
[root@SDC-MSE-01 ~]# cd /opt/installers/
[root@SDC-MSE-01 installers]# chmod 755 CISCO-MSE-L-K9-7-0-201-0-64bit.bin
[root@SDC-MSE-01 installers]# /etc/init.d/msed stop
Stopping MSE Platform
[Thu May 12 18:30:27 EST 2011] Local watchdog process stopped.
Checking the status of MSE Platform processes...
MSE Platform shutdown completed.
[root@SDC-MSE-01 installers]# cd
[root@SDC-MSE-01 ~]# /opt/installers/CISCO-MSE-L-K9-7-0-201-0-64bit.bin
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Preparing CONSOLE Mode Installation...
Cisco Mobility Services Engine (created with InstallAnywhere by Macrovision)
Introduction
InstallAnywhere will guide you through the installation of Cisco Mobility
Services Engine.
It is strongly recommended that you quit all programs before continuing with
this installation.
Respond to each prompt to proceed to the next step in the installation. If you
want to change something on a previous step, type 'back'.
Licensing on the Mobility Services Engine is enforced with the release of
software version 6.x and greater. Please have the Product Authorization Key
(PAK) and refer to the instructions in the User Guide to enable licensing.
PRESS <ENTER> TO CONTINUE:
Cannot find all database installers parts
Download all database installer components and then attempt installation
Exiting install operation now...
05-13-2011 08:26 AM
[UPDATED May 13, 2011 at 12:30 p.m. EDT: Thanks, Matthew Sarantakos!]
To remove (OPTIONAL) the files that you had transferred over previously, you can run the command
rm -rf
There are five files as part of the software upgrade to the MSE 7.0.201.204 release bundle:
1) CISCO-MSE-L-K9-7-0-201-204-64bit.bin.gz
2) database_installer_part1_4.zip
3) database_installer_part2_4.zip
4) database_installer_part3_4.zip
5) database_installer_part4_4.zip
These files are available at
http://tools.cisco.com/squish/9AD29
Transfer these five files *MANUALLY* via FTP to the MSE using these steps as reference:
http://www.cisco.com/en/US/docs/wireless/mse/3310/quick/guide/MSE10_c5.html#wp1053852
Once you've downloaded and transferred the code over to the MSE, rename the "database_installer" files by issuing the commands:
cd /opt/installers
cp database_installer_part1_4.zip database_installer_part1of4.zip
cp database_installer_part2_4.zip database_installer_part2of4.zip
cp database_installer_part3_4.zip database_installer_part3of4.zip
cp database_installer_part4_4.zip database_installer_part4of4.zip
(FYI: The underscore symbol is replaced with "of" in the file names.)
Then run the following TEN commands prior to the installation of this new code:
chown root:root CISCO-MSE-L-K9-7-0-201-204-64bit.bin.gz
chown root:root database_installer_part1of4.zip
chown root:root database_installer_part2of4.zip
chown root:root database_installer_part3of4.zip
chown root:root database_installer_part4of4.zip
chmod 755 CISCO-MSE-L-K9-7-0-201-204-64bit.bin.gz
chmod 755 database_installer_part1of4.zip
chmod 755 database_installer_part2of4.zip
chmod 755 database_installer_part3of4.zip
chmod 755 database_installer_part4of4.zip
When you run the command "ls -al /opt/installers" you should see "root" being the owner of all five files. Then please proceed as follows:
gunzip CISCO-MSE-L-K9-7-0-201-204-64bit.bin.gz
/opt/installers/CISCO-MSE-L-K9-7-0-201-204-64bit.bin
/etc/init.d/msed start
Let me know how it goes.
05-13-2011 09:07 AM
All:
I had the same issue as the original post. But to correct my problem I had to do the following....
After downloading the Files from Cisco.
database_installer_part2_4,zip
These files needed to be renamed before uploading themm to the MSE.
After doing this the Install script executed correctly.
Matthew Sarantakos
Exelon Corp. LLC
05-13-2011 09:23 AM
Matthew,
Thanks much! I'll correct the instructions in my previous post too.
- Varun
05-13-2011 09:56 AM
Ok. I just noticed that the upgrade instruction listed the files with the "of" instead of the underscore that you get when downloaded.
Thanks.
Matthew D. Sarantakos, NSO
Technical IT Analyst
Data, Video, Voice, Cyber Security Services
Byron Station
4450 N. German Church Rd
Byron, IL 61010
Phone: 815-406-4707
Email: matthew.sarantakos@exeloncorp.com
P Please save paper, do not print this e-mail unless you really need to.
05-15-2011 06:12 PM
Ok fixed.
There were two issues-
- The original 7.0.201.0 image I tried to upgrade with. Fix use the newly posted 7.0.201.214 image.
- Rename the ZIP files as they are named incorreclty when you download them. There should be an "of" in the name.
07-20-2011 02:40 PM
I have a question about the MSE version 7.
Ive installed it but whenever i try to start up the MSE Platform, it shows me that it is starting and its waiting to check the status. It shows me that line like 10 times and then it finally says there was an error with the status checkup.
Additionally, how can i see the configuration of the server?
i write getserverinfo but it doesnt show me the configuration i made!
please i would appriciate any help
sincerely
Dante Verastegui
