MSE 7.5
Does anyone know how to upgrade license from MSE 7.3 to MSE 7.5 or we need to buy new ones?
Thank you.
2 Accepted Solutions
Scott Fella
The license has changed from MSE v7.3 which you have. On v7.4 it has changed to AP counts which is on the honor system to use. On v7.5, the license is mandatory to buy. On your version it was based on elements and now on v7.5 its based off of APs. The ration is 50 elements per AP.
-Scott
Jacob Snyder
Level 5
Level 5
Contact you AM. They will assist you getting your licenses adjusted in the new model.
6 Replies 6
Saurav Lodh
Level 7
Level 7
Hello Kirill,
The MSE licenses are based on number of access point not on the MSE software code. Licenses are additive. You just need to upgrade your code. Follow the two below links
http://www.cisco.com/en/US/prod/collateral/wireless/ps9733/ps9742/data_sheet_c07-473865.html
http://www.cisco.com/en/US/docs/wireless/mse/3350/release/notes/mse7_0_201.204.html
Thank you, I know it.
I must update  mse from 7.3 (with license 3000 tags) to mse 7.5 which will convert my license to 60 ap, but  i have 560 APs. How i can purchase support for all my access points?
Scott Fella
-Scott
+5 for Scott
Haha... I just went thought that with a customer of mine yesterday:)
-Scott
Jacob Snyder
Level 5
Level 5
