12-03-2012 09:00 AM - edited 07-03-2021 11:09 PM
This is an unusual situation:
I have the need to run a few autonomous APs (1262) for some sites on satellite links.
At a bare minimum I need to run two WLANs.
One is wide open, and the other with an ACL that heavily restricts access.
Is there any way to tie two WLANs to a single VLAN, while applying an ACL to just one WLAN?
Any ideas?
Solved! Go to Solution.
12-03-2012 09:38 AM
You would need to setup multiple vlans. Here is a doc regarding autonomous and ACL's.
https://supportforums.cisco.com/docs/DOC-13768
12-03-2012 09:04 AM
On autonomous, you cans have multiple ssid pointing to one vlan. You can on a WLC.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
12-03-2012 09:31 AM
Kind of figured that.
I guess I will have tpo deploy another VLAN/Subnet...
I take it that I can run an extended ACL on an autonomous AP and apply it to the dot11 radio subinterface?
12-03-2012 09:38 AM
12-03-2012 09:41 AM
